Sherman pershing .
Post new topic Reply to topic RC-PANZER Forum Index -> La Documentation -> Photos d'archives -> Véhicules alliés
melich
PostPosted: Tue Jun 3 2014, 13:27 Post subject: Sherman pershing . Reply with quote
voila sur quoi je suis tomber sur le net (du peu d'infos que j'ai c'est un proto ):
PostPosted: Tue Jun 3 2014, 13:27 Post subject: Publicité
Didou74
PostPosted: Tue Jun 3 2014, 22:36 Post subject: Sherman pershing . Reply with quote
lol je le conaissais pas lui ! Quelqu'un a des infos sur se proto ?
PostPosted: Tue Jun 3 2014, 23:42 Post subject: Sherman pershing . Reply with quote
Une tourelle de Pershing sur une caisse de M4.... rien de plus.
melich
PostPosted: Wed Jun 4 2014, 14:27 Post subject: Sherman pershing . Reply with quote
Oui Didou , j'ai trouver ca .
source : Sherman a history of american tank
... "As a result of the crisis in Normandy, Brig. Gen, Joseph A. Holly returned to the US in July '44. As Chief of the Armor Section for the ETO, he was directed by Gen. Eisenhower to expedite the production and shipment of more powerfully armed tanks and tank destroyers, particularly those with 90mm guns. During his visit to the Detroit Arsenal, Gen. Holly viewed a Sherman armed with the 90mm gun M3. This was an M4 fitted with a Pershing type 90mm gun turret. Since both tanks had 69 inch turret rings, such an installation required only stowage changes and modifications to obtain adequate clearance between the turret assembly and some components on the tank hull. The experimental vehicle was fitted with the early vertical volute spring suspension (VVSS) and with the 16-9/16 inch wide track."...
... "À la suite de la crise en Normandie, Brig. Gen, Joseph A. holly est retourné aux États-Unis en Juillet 44. En tant que chef de la section Armure de l'ETO, il a été dirigé par le général Eisenhower pour accélérer le production et l'expédition des char lourd et des chasseurs de chars, en particulier ceux des canons de 90mm. Lors de sa visite à l'Arsenal de Detroit , le général holly a consulté un Sherman armé du canon de 90mm M3. Cela a été un M4 équipé d'un 90mm pistolet de type Pershing tourelle. Puisque les deux réservoirs ont des anneaux de la tourelle 69 cm, une telle installation exige que des changements et des modifications d'arrimage afin d'obtenir un dégagement adéquat entre l'ensemble de tourelle et des composants de l'enveloppe du réservoir. l'véhicule expérimental a été équipé avec le début vertical suspension volute de ressort (VVSS ) et avec la voie large 16-9/16 pouces. "
Post new topic Reply to topic RC-PANZER Forum Index -> La Documentation -> Photos d'archives -> Véhicules alliés All times are GMT + 2 Hours
