Leopard I 1:16 Scratch build
Post new topic Reply to topic RC-PANZER Forum Index -> NOS CHARS ET SEMI-CHENILLES -> Les véhicules allemands -> Les chars -> Le Leopard I
chris3
PostPosted: Sat Mar 15 2014, 23:31 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
here are some impresions from ouer LEopard 1 Scratchbuild PRojekt.
cu christian
PostPosted: Today at 10:47 Post subject: Leopard I 1:16 Scratch build
PostPosted: Sun Mar 16 2014, 00:08 Post subject: Leopard I 1:16 Scratch build Reply with quote
Vert good Job Chris !!!!
chris3
PostPosted: Thu Jul 24 2014, 23:32 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
thank you :-)
today i did some work at the suport rolers
the suport weels are way to big but it will still worl when the suspension works to its full range
cu christian
PostPosted: Fri Jul 25 2014, 09:42 Post subject: Leopard I 1:16 Scratch build Reply with quote
very good job Christian
chris3
PostPosted: Fri Aug 1 2014, 22:34 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
thank you :-)
some lidel update at the leopard, the tracks and track adjuster mounted and a test gear box is truen in to see how it will fit.
cu christian
chris3
PostPosted: Fri Sep 5 2014, 15:20 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
today i worked a bit on the gun holder :-)
and it works :-)
cu christian
Didou74
PostPosted: Fri Sep 5 2014, 23:05 Post subject: Leopard I 1:16 Scratch build Reply with quote
nice job christian is very awesome ty ty
chris3
PostPosted: Sat Sep 6 2014, 04:17 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
thank you :-)
cu
chris3
PostPosted: Mon Oct 6 2014, 23:02 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
lidel update on the tank
cu christian
chris3
PostPosted: Mon Nov 3 2014, 01:43 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
A lidel step forward :).
Cu christian
chris3
PostPosted: Mon Nov 10 2014, 21:53 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
now the work on the final prototyp and the manual beginns, i want to show you how this scratch kit will be made.
cu
chris3
PostPosted: Mon Dec 29 2014, 01:44 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
sorry, this projekt did do alot of progress in the last times.
if you want to see some more detail from any place let me knew, i sorry for i have forgoten these threat :-(
cu christian
chris3
PostPosted: Fri Apr 24 2015, 01:22 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
put in a new gearbox for the turret turning.
cu christian
PostPosted: Fri Apr 24 2015, 06:19 Post subject: Leopard I 1:16 Scratch build Reply with quote
Just a simple word: amazing TYPO
chris3
PostPosted: Sun Jul 26 2015, 04:00 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
thank you :-)
cu
chris3
PostPosted: Mon Aug 3 2015, 01:23 Post subject: Leopard I 1:16 Scratch build Reply with quote
hi
i did some work on the mudgards :-)
cu christian
PostPosted: Mon Aug 3 2015, 07:10 Post subject: Leopard I 1:16 Scratch build Reply with quote
Is it 3D-print-part?
chris3
PostPosted: Mon Aug 3 2015, 09:03 Post subject: Leopard I 1:16 Scratch build Reply with quote
Hi
yes the gray parts are made wirh a 3d printer.
Cu Christian
chris3
PostPosted: Sun Aug 23 2015, 14:12 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
did some work at the gun and turret movement .
cu christian
chris3
PostPosted: Tue Nov 10 2015, 15:46 Post subject: Leopard I 1:16 Scratch build Reply with quote
moins
i needed a lidel bracke from my 1A4 because the electronick stuff didn t work as it should be an i started working on his older Brother .
cu christian
Post new topic Reply to topic RC-PANZER Forum Index -> NOS CHARS ET SEMI-CHENILLES -> Les véhicules allemands -> Les chars -> Le Leopard I All times are GMT + 2 Hours
